Looking good Ben!
I just got a bunch of dewalt cut off wheels on sale for 1.50 each I`m happy with how long they last.
Walter works great too.
You got an auto darkening helmet? May need to lighten 1 shade. I've done that a couple of times when it's too dark, can't see exactly. Also helps to have good area lighting.
Got to be to late to run loud power tools so I had to come inside. I try to call it quits at no later then 7:30
I hope that weld is behind the center line of your bump cans. If not, have fun beating your bump stops into them :)
When i weld in bump cans, I now put the HF exhaust pipe expander in them and crank it up and then weld. I found that out on my front bump mounts which suck to put the bumps in. My rears I can loosen the bolts and it drops right out.
Your're too nice to the neighbors....
I will work until 9:00 with no concern about power tools.
But my old butt quits before then nowadays.....
I figured if the neighbors are happy I quit then they will put up with it all weekend. They already give me weird looks when I leave for work at 6:20am come home at 6:20 pm then see me still working into the dark.
Gotta set the standard low. You've set it too high. Work till noise ordinance kicks in usually around 10
Then when you clean up your act and ditch the yard ornaments and only play the death metal @blazinzuk recommends until 10, the neighbors are pretty happy
I have a new neighbor musical mix. Metal, opera, zydeco, bluegrass, classical, and 80s pop music. Little old school rap with some acid jazz thrown in.
This will guarantee they either never talk to you or let you do all sorts of stuff cause your eccentric
