I thought that's what it was but wasn't sure
After I took the first picture I just put my head down and knew it was going to hit...
On the plus side, when you cut off the mount for the limit strap, you'll get a good look at your weld and see how ya did. :D
It's not pretty, there is a reason I took the picture the way I did hahaha
Don't ever look at any of my builds then...
You're doing awesome work. Your welds are looking better and better. Keep up the good work. It'll pay off.
Thank you sir, I think It's getting better and better every time.
Mine were scratched out in the dirt. Too many wind storms since then
It feels like it.
I bought the wrong length straps, I'm going to try something on the other side tomorrow and see how well it works.
Set the mounting points st full stuff both sides, you now have mockup straps to make sure they curl right and don't bind. Get the mounts done, measure for straps and order them.
Well the straps will not work so I'll have to order a different set.
I jacked up the truck on the bump stop and it didn't flex at all so I think I'm good.
Just got back from charging them full of nitrogen.
Would this be a bad thing mounting these at a angle? Or should I just wait until Monday and hopefully poly performance will exchange them?
Just trying to get stuff done and thinking.
