If I remember correctly the wiring connector is a Weatherpack style.
It is a flat one, at least 6 prong or so.
I’m really unfamiliar with these tank selectors, I have never seen one or worked on one.
I was thinking about sense it’s a 20 gallon tank to use a short filler and stick the nozzle in the wheel well. Also for switch I thought I could program the pro dash to handle that.If your truck didn't have it from the factory you will need to cut a rectangular hole in the dash and add a filler on the other side of the bed and wire it all up, not exactly easier than putting the tank in the back.
Does the switch have both momentary and constant poles? Or does the valve switch the sending unit too? I don't remember but it needs to be switched somehow because the gauge stays on whatever tank you switched it too...The valve needs a momentary power signal to actuate the change in position. This is why the factory switch has a note on it "Depress Fully" . Once you release the switch, the power delivery stops. It flips which direction the valve spool is moved inside the switch.
I installed one in my old '68 decades back. But I was able to find new parts and junkyard parts to do then.
I was hoping to do the fuel level sensors into the Holley having 2 gauges at all times but this would work to.Does the switch have both momentary and constant poles? Or does the valve switch the sending unit too? I don't remember but it needs to be switched somehow because the gauge stays on whatever tank you switched it too...
That part is fuzzy in my memory. I don't remember if the sender wires went to the valve or the switch.Does the switch have both momentary and constant poles? Or does the valve switch the sending unit too? I don't remember but it needs to be switched somehow because the gauge stays on whatever tank you switched it too...
I don't remember either and I tore it out when I converted my factory switch to a transfer pump. If I momentarily press the button, it just switches the gauge to see the tank levels. If I hold it down for two seconds, then it starts to transfer the fuel until one is empty or the other is fill, whichever is first.That part is fuzzy in my memory. I don't remember if the sender wires went to the valve or the switch.
I would have to dig out a manual to look.
With your injectors you can likely keep the max at 43 psi, engine vacuum will only lower it from there.It says 60psi, I will probably test the limit of that lol.
