I've had this truck for 9-1/2 years, and have built it up from stock. Check that link for pics.
- 6.2l diesel with Banks turbo, serpentine drive, & Fluidampr
- Carter electric lift pump, FM100 fuel filtration, Kennedy Diesel injection pump
- Manual glow, starter, TCC lockup, and injection cold-idle advance switches
- Manual windows, floor vents, and heat mixer door (factory push-pull cable).
- Bowtie Overdrives Stage II 700R4, NP208 TCase
- High-Angle Driveline 1350 rear driveshaft (stock front shaft), Spicer Life joints
- Open D60 front, 14BFF rear with Detroit Locker and Sky Offroad disc kit - 4.10 gears and 3/8" RuffStuff diff covers
- Missouri Offroad Outfitters rear shock inboarding kit, Bilstein 5150 shocks all around
- ORD crossover, highsteer, and engine crossmember
- ORD (Alcan) 4" front springs, ORD 4" rear shackle flip
- XJ steering shaft
- 315/75R16 (35") BFG AT tires (Date code July 2013)
- 3" mandrel-bent straight-pipe from the turbo back
- Banks boost and EGT gauges
- Delta sidesaddle tool boxes
- H4 headlight conversion
- Stock AM radio with UniSound
- Rebuilt engine installed
- New BTO transmission
- Axles rebuilt, upgraded, & installed with new brake calipers and discs
- All new steering/suspension components (except rear springs)
- New Kennedy injection pump
- New serpentine system and engine accessories installed (new pulleys, PS pump, alt, water pump, fan clutch & fan, idlers)
- New radiator, hoses, and steel trans cooler lines
- New batteries
- All new battery and starter cables (1/0 AWG)
- New starter
- Has one spot of cancer behind the rear passenger-side tire. It's been there since I got it, and I live in the desert so I never addressed it. Otherwise a rust free California truck.
- The speedo and fuel gauges don't work. I use GPS for speed and mileage. The dash-mounted Garmin stays with the truck. Aftermarket oil/temp/voltage gauges are installed in the bezel and do work accurately.
