Good morning!
This is my first post here on Colorado K5. I have spent some time reading and researching, but need some expert help on a few issues my blazer has.
Primary use: hunting transportation here in Georgia
Specs:
305
A/C - but doesn't work
auto
31x10.50 tires
and rust !
What I've done:
1. New battery
2. New pads on front brakes
3. Completely rebuilt rear brakes
4. Removed smog pump and sealed hoses
5. Fixed some rust on hood and side and gate
6. Replaced rear bumper
Problems:
1. Idles way too high - my Father thinks it may be an O2 sensor on the carb or something? Help here is greatly needed.
2. Rust - I'm working on that
3. Power steering pump leaks
4. Fuel gage doesn't read past a quarter tank - on the low side
5. A/C doesn't work
6. The exhaust stinks so bad you can use it as a pesticide
My ideas:
I had an '87 Toyota 4x4 that I put a weber carb on and it did wonders for how the truck ran. Thinking of putting an aftermarket carb on the K5 - just need some suggestions on a good, reasonably priced aftermarket carb. However, if the stock carb is good and just needs adjusting let me know.
I would like to simplify the engine i.e. pull all the smog equipment, charcoal canisters etc. and keep as mechanical as possible. I'm thinking of pulling out the catalytic converter. I just want the vehicle to run smoothly, not stink of exhaust - big issue here b/c I am a bowhunter - and I'd lilke the A/C to work.
I bought a 134a conversion kit. Does this work well on the K5s since it is an R12 system?
I'm sure I'll have more questions later. I appreciate any and all help.
thanks
Specs:
305
auto
31x10.50 tires
and rust !
What I've done:
1. New battery
Problems:
5. A/C doesn't work
My ideas:
thanks
There's a track in the door that's horizontal, and has two plastic rollers in it. It's like a scissor action--as they get pulled closer together, the window goes up. So make sure the rollers are in good shape and lube it up. I just remembered, you can get the lithium grease in spray-can form, which makes it real easy to lube everything up. It's a common parts-store item.
