blazer88
Registered Member
Finally pushed to the edge and am selling my blazer. It is an 84 with a crate 350 about a year old, and a 700r4. It has a 4 inch suspension lift and a 3 inch body lift. 4.88 gears 8.75 inch rear end, or whatever is stock. Runs on 37x12.5x15 inch interco tsl. I have done a lot to keep it on the road, bear with me I will list all of that. Most recent was a carb rebuild by a local shop in Fresno called CADS. All other work done by a shop called AllTech, in Clovis. Replace distributor, new ignition control module and pick up assembly, new oxygen sensor. Welded a cross member that came loose when rivet gave way. Here we go, power steering gearbox, ball joints, rebuilt brake calipers, brakes, oil seals(rear axles) bearings(rear axles) brake drums, rear brake shoes, longer wheel studs, ord weld in frame repair kit for steering box, along with the bolt on part of it. Replaced slip yoke(rear) and u joints. Choke pull of and EGR were replaced. I think that is about it. If you have any questions email me @ [email protected] or call or text @ 5594307516. I am asking $4799.00. Sorry for the standard picture I can email more.
