1984 K5 Computer
I searched for it. Dont know if this is the one you saw, but it covers it pretty good. ESC/ HEI
z /forums/images/graemlins/thumb.gif
That's it!
The pink wire they're referring to is the ignition wire on your distributor cap. It's a #10 wire or so with a funny looking plug on the distributor cap. If you've ever replaced your cap, you plug the distributor into the same plug in area.
The two plugs are piggy-backed. Unplug it, plug the big pink wire into your cap, and the little wire can come out.
The wires are cut, soldered and taped, plugged the pink wire in only, what about the knock sensor? disconnect?
Running great so far /forums/images/graemlins/thumb.gif Thanks guys for all your help /forums/images/graemlins/thumb.gif do I need to disconect the knock sensor?
So is it running better (hopefully perfect, especially if ESC was the problem) now that the ESC is apparently bypassed?
You can unplug the knock sensor, or just save yourself work and leave the wire in place I guess. Might need it if you ever decide to go FI. /forums/images/graemlins/smile.gif
Running better than it ever has, thanks again for your help... /forums/images/graemlins/thumb.gif
700R4 Throttle Valve (TV) Cable Adjustment
The Throttle Valve Cable is attached to the throttle linkage. When the throttle is depressed, the cable is "pulled" progressively with throttle position. In addition to providing forced downshifts (kickdown), and progressively later (higher speed) upshifts at higher throttle settings, the throttle valve also adjusts main line pressure in the transmission. Operating a transmission with the TV cable out of adjustment, can, not only produce early, or late upshifts, but incorrect line pressure, as well. What this means, in simple terms, is that TV pressure that is too low, will produce main line pressure that is also too low, and will eventually "burn" the transmission clutches.
To adjust, on the throttle linkage you will have three things attached if you have cruise, two if not. One of them is of course for the gas, the one that is for the cruise control has a long slot in it (if you have cruise control), and the other is the TV cable (which is actually a cable), this is the one you need to adjust. Adjust the cable so that it will be pulled all the way, when the throttle is simultaneously opened all of the way (with the engine turned off, of course). The way to do this is, bolted to the manifold is a bracket which this cable runs through. With close inspection you will see it has a sort of D shaped button you can depress and slide the sleeve (cable housing) back and forth. The sleeve is what you want to adjust, by depressing the button. Press the D button and slide the sleeve toward the firewall as far as it will go and let go of the button. Now open the throttle to the wide open position and release. You should be able to hear the sleeve click (rachet) as it slides through the cable housing. Make sure that the cable returns (with no binding) when the throttle is released. This preliminary adjustment will frequently be too "high", and the throttle pressure will have to be reduced, to attain proper shift points. I prefer to start with an adjustment that is "too high", and then work down, rather than "too low" and work up.
To raise throttle pressure (and raise shift points, and make "kickdown" more responsive) move the cable housing towards the firewall (away from the throttle linkage), as you simultaneously depress the button on the cable housing, move the cable housing away from the carburetor or (throttle body) to increase throttle pressure. Move the cable housing adjustment a small amount at a time (1 click or 1/16" or so), a small adjustment can often make a world of difference. Naturally, to lower the pressure (and lower shift points, and make "kickdown" less sensitive), move the cable housing towards the front of the truck.
1987 Chevy S-10 Blazer Supercharged 3.4 V-6 TBI
Dont mean to go off topic, but i swapped in a 350 with a carter carb and no emissions equipment. My question is I have the 700r4 and now it doesnt shift right. Ive seen kits to convert non ecm motors to the 700r4. It kinda wanders and the shift points seem different. Newbie mistack? I dont need emissions in my county would love to go to a 6.0l someday. (with a little help) Thanks
[/ QUOTE ] [ QUOTE ]
You just need to adjust the TV cable properly . It will be off now , the carbs are different with linkages not exactly in the same spots at certain throttle positions . The 700r4 is not electronic , except for the lockup /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
