I got (basically) everything replaced between the clutch pedal and the transmission!
- New clutch master cylinder
- New hydraulic line
- New slave cylinder
Bleeding the new stuff was kind of a pain, but I compressed the new slave cylinder using zip ties and that helped a lot.
Now that I am done, I have a couple of questions...
- The truck wouldn't start after I did the job because of the neutral start switch. I added a few zip ties onto the switch so that I could artificially shorten the "stroke", and it started up after that. I don't know what would cause the pedal travel to change and am a little confused by that. Maybe the new master cylinder has a longer actuator arm thing that connects to the clutch pedal?
- Once I got the truck fired up, I test drove it and everything felt good. That being said, I recorded a video of the slave cylinder pushing out and it doesn't look like it is extending all of the way. I could shift through the gears just fine, so maybe it doesn't matter. What do you guys think?
Pics and video from the job are below!
View attachment 486425View attachment 486426View attachment 486427View attachment 486428
