This thread is for the general discussion of the Item 1986 K5 LS Swap/ Resto. Please add to the discussion here.
How are things progressing?This thread is for the general discussion of the Item 1986 K5 LS Swap/ Resto. Please add to the discussion here.
I used pipe stands and jacks. I jacked the front up and ran a 2" gas pipe across the inner frame rails on the pipe stands. I then repeated the process for the rear.What did you use to get the cab off the frame? How heavy is the cab?
Things are going well. I'm getting closer.How are things progressing?
