When I was spraying Carb and choke cleaner through the passage that goes through the top half of the pod and into regulator it wasn't coming back out anywhere else
I don't know how a spider would get in. Unless it was living in the new filter. I would pull it apart again, and make sure everything went in straight. I had a o ring twist. Ran fuel in fast.
no I borrowed one from a friend but didn't have the right fitting and don't have the money to rent one tomorrow ill check injector o ring then after that if it don't wanna stay running ill just rob a auto zone and get a pressure tester
