grtwhite
1987 GMC 3500 Pickup
Hate to do it but I’m selling my truck. Truck runs & drives fine. Haven’t had a chance to replace passenger side door, cab corner, or fuel pump ( has dual tanks). Also have plenty of parts I never got around to installing. Selling cause I need some funds for home improvements.
Specs:
- 454 TBI motor
- Dana 60
- 14blt
- 3.73 gears
- th400 trans with transgo shift kit & deep aluminum pan
- 205 transfer case
- power windows & locks
- AC
- dual gas tanks
- hydro boost brakes
- 4 inch suspension lift (blocks in rear, unknown manufacture)
- 35” BFG all terrain ko tires
- Myers 7.5” plow
New parts installed in the last year:
- drivers window motor
- stainless steel trans cooler lines
- headlights
- tune-up
- radiator &hoses
- belts
- ignition coil
- rear driveshaft u-joints
- 130 amp alternator
- starter & remote starter solenoid
- thermostat & housing
- EGR valve
- dual batteries
- hydro boost master cylinder
- front calipers & pads
- rear wheel cylinders
- stainless steel brake lines (all replaced flexible & hardlines)
- front shocks & steering stabilizer
- front suspension poly bushings
- ORD front shackles, greaseable
- ORD swaybar disconnect
- ORD weld in & bolt in steering box brace kits
- XJ steering shaft
- steering box
- husky floor mats
- Dana 60 king pin bushing & spring kit (too eliminate death wobble)
Asking $4000 OBO
Specs:
- 454 TBI motor
- Dana 60
- 14blt
- 3.73 gears
- 205 transfer case
- AC
- dual gas tanks
- Myers 7.5” plow
- headlights
- tune-up
- radiator &hoses
- belts
- ignition coil
- EGR valve
- dual batteries
- XJ steering shaft
- steering box
- husky floor mats
Asking $4000 OBO
