1987 GMC 3500 Pickup (Price Reduction)
grtwhite
Macungie, PA
Hate to do it but I’m selling my truck. Truck runs & drives fine. Haven’t had a chance to replace passenger side door, cab corner, or fuel pump ( has dual tanks). Also have plenty of parts I never got around to installing. Selling cause I need some funds for home improvements.
Specs:
- 454 TBI motor
- Dana 60
- 14blt
- 3.73 gears
- th400 trans with transgo shift kit & deep aluminum pan
- 205 transfer case
- power windows & locks
- AC
- dual gas tanks
- hydro boost brakes
- 4 inch suspension lift (blocks in rear, unknown manufacture)
- 35” BFG all terrain ko tires
- Myers 7.5” plow
New parts installed in the last year:
- drivers window motor
- stainless steel trans cooler lines
- headlights
- tune-up
- radiator &hoses
- belts
- ignition coil
- rear driveshaft u-joints
- 130 amp alternator
- starter & remote starter solenoid
- thermostat & housing
- EGR valve
- dual batteries
- hydro boost master cylinder
- front calipers & pads
- rear wheel cylinders
- stainless steel brake lines (all replaced flexible & hardlines)
- front shocks & steering stabilizer
- front suspension poly bushings
- ORD front shackles, greaseable
- ORD swaybar disconnect
- ORD weld in & bolt in steering box brace kits
- XJ steering shaft
- steering box
- husky floor mats
- Dana 60 king pin bushing & spring kit (too eliminate death wobble)
Asking $4000 OBO
If youre interested in selling any of the parts you have seperate, shoot me a pm.
I see you figured out pic posting? I got your email when I was getting ready to leave for the Arkansas trip. Didn't have time to post them. Wasn't too hard, was it?
What kind of shape was the frame in when you put weld-on steering brace on?
