1987 k5
Coloradochevyguy91
Registered Member
Coloradochevyguy91 submitted a new Build:
1987 k5
View attachment 222068 View attachment 222071 View attachment 222072 View attachment 222068 View attachment 222071 View attachment 222072 Hello all,
I'm new to this site and I just thought I would share my project. It is a 1987 Chevrolet k5 350 tbi, 700r4/208 with 10 bolts front and rear 3.73 gears. I bought it in august of this year for 600$. The previous owner and I had been exchanging text messages for a year he wanted me to him a trans for it. Since he let a friend borrow it to do some stuff he ended up taking it mudding and destroyed the transmission. So it sat for a year since the owner couldn't find a trans for cheap. I have had for about ten years an 86 k5 sitting in my drive way because the rear axle was shot and the motor was seized. And I lost interest due to other projects. Back to the 1987 he called me up and said he didn't want the truck anymore due to bills and the apartment complex was hassling him about it not moving in a year and said come pick it for 600$. So I ran up from Littleton Colorado to Longmont co and had it brought home. Once it was home I tried staring it, it would crank over but not fire up so I went through the normal steps. Air, fuel, spark, and compression and I was missing fuel so I checked the relay, it was good so I jumped to dropping the tank I ordered up a new sending unit, fuel pump, and filter. I installed all but still I couldn't hear the pump at all! Back to diag! Checked ground looked for fuses all good? I took a look on thirdgen.com found that the ignition control module might be to to blame I had a spare one in my parts bin and threw it in. And BAM! It fires right up like new changed plugs and air filter and ohm out the wires and called it a day. Next day I tried putting it in any gear and nothing! So I started looking at my 1986 blazer which has a seized 350 but, with a good 700r4. So swapped out the trans new filter and fluid here it is now a daily driver.
Parts I have acquired since then.
1. Dual shock brackets
2. Carr light bar with 6 kc day lighters
3. Winch bumper with four more kc's
4. Long tube headers
5. 4" Rancho front leaf springs
6. ORD shackle flip kit and new front u bolts
7. Np 205
8. Dana 44 8 lug 4.10 gears and powertracs LSD I THINK!!
9. 14 bolt ff 4.10 open diff
10. 700r4 rebuilt
I am missing some key components for installing these for example the lift kit I need extended brake lines, 6 new shocks. But I will post pictures and such when they...
Read more about this build here...
So a couple of updates on my truck... first the transfer case blew up I need to open it up. And find out what went wrong. IMG_3118.JPG Next the transmission tv snapped and the 7004 soon followed... so off to the tranny shop...IMG_3311.JPG
So while the truck is down I found that the filler neck tube that goes into the tank the weld broke somehow! 51114313118__3FDF0E93-1640-4F67-8EBD-F33A502F0775.JPG 51114312320__FA4FA5EC-99D0-4394-B392-14A2EA5C39EE.JPG Had my buddy reweld the tank.
IMG_3377.JPG IMG_3376.JPG So next will be the lift kit (4 inch) . I need to order extended brake lines and the rear shackle flip kit with and an inch blocks from ord. And long tube headers with a new true dual exhaust with flow master 40's. But I have to wait for money I started a new high paying job to pay for this crap lol. But that's all I got.
welcome to the driveway builds... what is your plan in the end daily driver or offroad machine?
I currently have two blazers this one will be the off road truck locked front and rear. I have a Dana 44 hd 8 lug with 4.10 gears and lunch box locker and truss. I'm looking for a 14 ff and replace the 208 for a 241 for the low range and I can run the SYE. I want to run 37's with the 4 inch lift and the add an inch and cut the body ( it's pretty rusty and has large holes). But I want to drive it to every trail no trailer.
