They are. I did have one side re made because I crushed it trying to move things around. Otherwise with a little more finesse, the factory ones will bend.
No temperature testing. When we bought the truck it had an aftermarket R4 compressor and it was cold. When it crapped out, I went through a couple of the same brand compressors that just kept failing. I think it was roughly $600 ish using new parts. The new setup is quite and ac seems to be working well.
I wouldn’t hesitate to do it again. I like the simplicity of the serpentine setup. If you found a donor truck that had everything it would probably cost a lot less than piecing it together.
