Got some parts in from LMC Friday,
New brake pedal pad, swaybar bushings, and a new turn signal stalk.
A while ago I heard some clunking around up front and realized that there was no bushing on the driver's side of the sway bar where it bolts in next to the U-bolts.
Heres what was left of my bushings
Got some new grade 8 bolts and new bushings and everything went on well.
Next on the list of things to do was to replace the turn signal stalk. The piece that the stalk hooks into has an incredible amount of slop which makes it difficult to keep my right blinker on and ultimately is the reason why I accidentally snapped my old stalk off. My left blinker has no problem staying engaged so I'll need to dig into that at some point.
Here is the new one:
I tied some fishing line to the connector on the old stalk and pulled it up through the column, then I tied the line to the new connector and pulled it all the way back down the column. That made it super easy to do and I don't know how else you would do it because the column is kind of tight.
Here is the new one all hooked up! Looks weird with all the white lettering since my old one had long faded off
Thats all I have planned for now. At this point I'm just saving my pennies for an ORD 2" lift kit and some 33-inch tires. I am downsizing from a rough country 4" and 35's because I'd like to turn this into more of a road trip vehicle and less of a mudding truck.
