1988 K5 4-link crawler
wuan2000
Registered Member
Larkspur, CO
wuan2000 submitted a new Build:
Bought the K5 for $2800 June 2016 with a reman 350 TBI, 700R4, np208 with some weather checked tires. Ran good, shifted firm and the body was straight...so I thought "why not?"
Certainly a long list of items to do, and as with many, the limitations are often time, parts, money and spousal agreements to support. :smile:
Done so far:
- 10 bolts...gone. Leaf springs...gone. Stock fuel tank...gone. Steering box...gone.
- Entire body primered and coated with beige bed liner
- 14 bolt, Detroit Locker, 4.56, pinion guard, bridged and trussed
- Dana 60 front build underway; Detroit, 4.56, complete hub-hub rebuild, OX u-joints
- Bed cage; all bent here out of 1.75" .120 wall DOM
- Corbeau baja seats w/harnesses
- New radiator w/electric fan from Crown Vic on designated switch
- LED headlight conversion (upper white/lower ambers)
- 4-link brackets fab'd up and tacked in place
- New 37's Maxxis Trep's on 17" steelies
...I'm sure I'm missing other smaller items
To Do:
- Cut and TIG the links and tube adapters (2" .250 wall DOM)
- Shock/Suspension brackets on axles
- Bend hoops/CNC cut shock mounts for coilovers (King coilovers on all four corners)
- PSC full hydro front steer
- In-bed fuel cell
- Continue cage into cab
- Box in sections of the frame
- Taper front/rear for clearance(s)
- Cut out my own beadlocks and mount 'em
....and more.
I'm hoping to be on the trails by June. My original goal was Moab by mid-May, but that's not promising.
I'll keep up with photos as much as I can. I'm more of a hobbyist, but I do all of my own chassis/cage design, tube bending, cnc plasma/hand cutting, MIG/TIG welding, etc. Only a few items I get from other shops that have the means to press thick parts, etc.
View attachment 228446 View attachment 228447 View attachment 228446 View attachment 228447 View attachment 228448 View attachment 228449 View attachment 228450 View attachment 228451 View attachment 228452 View attachment 228453 View attachment 228454 View attachment 228455 View attachment 228456
Read more about this build here...
Got any info on the headlights and turn signals you installed? I like the cage design.
I'll look and see what I have. I honestly think those were an ebay purchase, but I'll confirm and let you know on the info.
Thanks- on the cage design.
Looks good! :waytogo:
Try slowing down on your travel speed a bit and it will get rid of some of that unevenness...and a bit more side-to-side "weave" when you draw the "Cs". That will tie in the parent metal more completely and keep the weld from getting too tall in the center.
-G
