Sold 1989 Chevy Suburban WA
Kenny, if you come across a tan rear a/c cover in decent shape give me a shout.
When you're healed up of course.
You oughta start a business, "Square Body Acres"!
Ive got 2, And we’re not across the country. Shoot me a pm
He does! C.H.O.P.
Chevy hoarders original parts
Technically, Squarebody Chevy Hoarders Original Parts Shop... aka Squarebody CHOP Shop. Although it is only a hobby. I have no interest in making it a business. I need to get my projects done and don't need to make money.
Well thats understandable. But either way, youve helped me out a few times greatly, and many others!
Front or rear AC? This does not have rear AC but the front looks to be on good shape. $40 for the whole assembly and you would need to pull it at this time or wait 3 more weeks for me to pull it.
I'd be interested in the radio antenna and mast assembly (part that screws to the passenger side fender with 3 screws). Shoot me a price for shipping to 64131, thanks!
This one still has the weld in floor brackets for the bucket seats. I likely have a set of sliders for the Suburban buckets on the shelf.
If you could check please. Ultimately going to go with different seats, but would like to get the stock ones in for mock up if nothing else
Is the floor weld in brackets different for buckets or bench? I though was straight forward swap between bench and buckets up front?
Hi Kenny, i’m looking for a second row, passenger side, seatbelt button/buckle that bolts to the floor. For some reason its missing from mine.
All trucks and Suburbans have the bench mounting points. The bucket seat trucks add two extra brackets that the bench seat trucks don't have for the front inner mounts and two extra holes/ nuts at the rear inner floor.
$100 shipped assuming everything is in very good condition when I pull it.
that'll work for me. let me know when you verify condition. should be the antenna, the mast assembly (with 3 screws) that the cable goes into, and a little cover piece that slips over the antenna and covers the screws on the mast assembly. I don't NEED the antenna cable itself, but if you have no use for it I'd take it also because you just never know what can go wrong....
I should be able to pull it this weekend. Send me a PM so I don't lose track of you.
Is that overhead console mount riveted into the supports? (Meaning that option was determined at factory, and not an easy add-on after assembly)
Mine doesnt have that. Trying to determine if worth grabbing that vs just fabbing something
