I was driving the truck and while driving the truck shut off. All electrical was still on like the radio and headlights. The motor just stopped. I checked all fuses, the battery has correct voltage. The motor cranks fine and I do see fuel coming out of injectors. I don't have spark coming from sparks plugs, but I do have 12volts going o the coil. I swapped out coil and still no start? Also my oil pressure gauge peaked over 60 and does not move any more when I turn ignition switch on.
