This thread is for the general discussion of the item 1989 K5 Blazer- not yet named. Please add to the discussion here.
Thanks for the insight! I forgot to mention in the post that the screeching issue is a very definitively bad driver side wheel bearing. The vibration could still be an unbalanced driveshaft, but it only happens at higher speeds, which leads me to think it might've been the crazy amount of slop in the tie rods. I'll still be using that tool you mentioned though.Good intro, sounds like your on a good path. Make sure you get both driveshafts gone through after you install your lift kit and get it back on the ground. That could be your screeching noise and vibration. Check out Tom Woods website. It gives you diagrams how to measure for correct shaft lengths and stuff.
All good plans. The 6.2/6.5 is a little funny, but read up more you'll learn.Some other things I'd like to do, in no particular order:
Dual battery setup, running an isolated deep cycle to power a winch, fridge, and onboard air compressor
Winch/winch bumper. I don't know what the general consensus about Harbor Freight winches is in this forum, but they're cheap and under warrantee and for a 24-year-old like myself, that's very appealing.
Order a soft top
Removable door setup from the guide somewhere on this forum
Build a big block or 6.2/6.5
More offroad lighting
Rock sliders (maybe)
Fix A/C (maybe)
Starter solenoid bypass via firewall-mounted solenoid
High torque mini-starter
Clean the undercarriage and paint/coat
- for this one I'm thinking of getting the $89 electric pressure washer from HF. It comes with a low-pressure nozzle w/ soap reservoir that looks like it would be perfect for degreasing
Repair minor dings/dents/rust spots and get a better looking coat of paint on
Sound system upgrades
Clearly I have plenty of objectives I want to complete. More will come up over time I'm sure, but this is a nice reference list to check my progress over time. Feedback always appreciated.
I know the DDs aren't the most incredible motors, I just like them. Don't ask me why lol.All good plans. The 6.2/6.5 is a little funny, but read up more you'll learn.
Most of your plans can be done well, even on the cheap. Dual battery setups are easy to do vs a $300 kit from painless or other known high ends brands.
One suggestion to add to the mix. Buy a welder. You can build your own bumpers and sliders. Learning another skill is just as important as making the upgrades.
It's not my primary, but I intend to sub it in for my daily often enough for that to not be realistic. I could get away with it but I'd rather not.Where you located in VA? Assuming this isnt your primary vehicle, you should get antique tags. Removes need for annual inspection and registration.
Oh, i'm in tidewater btw. Good ole 757.Where you located in VA? Assuming this isnt your primary vehicle, you should get antique tags. Removes need for annual inspection and registration.
