Old posi springpack is out, but does anyone have a recommendation on the best way to install a new one?
I mean the dust plate behind the drum, not anything on the housing/tubes themselves. I'll do a one ton and disc swap eventually, but this axle was rebuilt back in 2018 and has less than 100 miles on it since then. Gonna see if I can troubleshoot the issue one more time before I move on. I do appreciate the suggestion though.By "backing plate" are you talking about the metal dust cover? That can be easily tweaked with a crescent wrench or pliers.
Or are you talking about the plate that's welded to the axle tube? if that's the case, that would be a first for me. I'm certainly not a professional mechanic, but I've honestly never come across one of those bent.
Just food for thought here, but with the amount of frustration and money you have spent already, have you considered a disc brake swap? Several manufacturers out there make a kit. Or swap the whole axle for a newer unit with disc brakes already. I got my 14 bolt FF from an '04 for $100. Just giving options.
Great looking truck by the way.
That was my thought process too, and so I replaced the axle shaft, but the noise is still there. Funny enough, I actually noticed that the brakes aren't sitting totally perfect just last night, so you saying that really confirms it. The whole assembly was dropped once in transport, so that's probably what it is.Ok the noise is there with the wheel and drum on. Right? Take the wheel and drum off and the noise goes away.
The backing plate could be bent but you should be able to see that. Plus if it's not straight the shoes won't be lined up in the drum. Yes they can get bent but the drum surrounds it so it would be really hard to do with the wheel and drum on. Now if the axle got dropped to the ground off of a jackstand with no drum on it sure. But again you should be able to see it.
If you have the wheel and drum off have you watched the axle flange as you ran it? If the flange is bent it's going to force the drum to wobble and rub on the backing plate.
A bent axle flange on a 10 bolt is more common than bending the axle end or backing plate.
Bingo. Xj shaft works to eliminate slop of the rag joint.Check for frame cracks, they are a factory option.
Swapping the rag joint shaft for a Jeep XJ shaft with u-joints made a tremendous difference in steering feel on my Blazer.
I'll see if I can get someone to help with that. I just reinstalled my 10 bolt front eariler this year and used all brand new Moog hardware. Shouldn't be tre or dle but I'll check them anyways. This has been plaguing me for years.Bingo. Xj shaft works to eliminate slop of the rag joint.
Quick and easy diag would be to have an assistant steer the wheels right to left while you watch critical areas where slop can happen. First off the frame where the steering box mounts. A cracked frame would cause the frame to move where the box mounts.
After looking there, watch down the line, pitman arm to drag link, drag link to steering arm, ball joints on both sides and the tie rod ends on each side.
Any one of those joints can be worn out and sloppy. Add it to other sloppy items and you end up with a lot of slop that wanders all over.
