Queasyrida
Hi, I recently bought a one owner, 41k miles, '90 K5 (1500). The truck wanders at highway speed, there is about 2" of steering wheel play each side of straight up. I have checked the spindles, tie rod ends, cupping my hand over a joint, no lost motion. The pitman arm looked suspect so I tightened the pinch bolt with my impact wrench. It tightened about a half turn. No noticeable improvement. The rag joint has no play. It goes down the road centered with hands off the wheel. It's been over fifty years since I've worked on anything with kingpins so I may be missing something. Moving the steering wheel when parked, the pitman follows perfectly. Watching the tire the steering wheel will move about an inch from center before the tire moves, 2 inches total play.
The trans cooler line to the radiator blew today, rusted through. Should I try to make one solid line or use two pieces with a coupler? I have a tube bending tool. It looks like a good challenge!
This is my first post and I'm over the hill, so please bear with me.
