Sold 1990 Chevy Suburban R1500 [C10]
kennyw
@squarebody.chop.shop on IG
Stevens Pass Highway, WA
I picked this up for red interior parts and the transmission. This one has some Midwest salt rust but running boards protected the doors.
Located in Sultan, WA.
Sold:
Interior door panels
Passenger doors
Transmission
Rear axle
Rear bumper
Steering column
doors
motor
Rear wind deflector
Gauge cluster
Dash bezel
bucket seats
console
Front suspension and frame
sun visors
Rear heat system
Available
Roof rack $100
40 gallon fuel tank $25
Red dash pad, cracked w/ nice woodgrain AC trim $40
5 lug aluminum wheels $100/ set
GMC hood ornament $10
Factory antenna $25
Red seat belts $100/ set
Red overhead console $75
Anything else, just ask.
20220417_164619.jpg20220417_164615.jpg20220417_123050.jpg20220417_123054.jpg20220406_213354.jpg20220406_213357.jpg20220406_213405.jpg20220406_194526.jpg20220320_192651.jpg
How about this ones vss harness? Still haven't found one that's usable.
From the speed sensor up to the drac module.
Wiring is available for this one and I able to drive it and confirm the gauges work. $50 for the harness plus $16 for a medium flat rate. Pulling it may take a couple weeks until I get the motor and transmission out though.
Take your time. One request is pics of anything important related to the OEM routing of it so I can do it right. Just let me know when you got it and I'll pay you.
Dang...that was a nice burb...
How bad would shipping be on the TBI setup to 47130? Can you include the air cleaner assembly? Assuming it is everything needed to run except o2 sensor/fuel pump.
Good chance it would run over $200 for shipping alone. It ends up being a fairly large box with all the wiring, computer, TBI, manifold, etc. Including the oxygen sensor would be easy but good chance you would want a new one anyway.
Any reason not to just run a spreadbore to TBI adapter? Would save a bunch of shipping weight. I was considering an afi kit, but the more I think about it, a used setup could work and if a few new parts are needed then that’s ok.
Edit: I need to read more about the distributor, if that is needed also
Never seen the pockets with the flap cover, was that a suburban only thing? Or a fancy upgrade?
Hmm, gives a much cleaner look, will add it to the list of interior parts to look for my truck
The distributor is controlled by the computer and required as well.
You can get away with an adapter in a carb intake if they are available but the one temp sensor mounts in the intake.
Does the rear heat kit include ducting, blower, vents, and wiring?
The factory rear heater mounts to the floor with no duct work. It does have a stand alone wiring harness to reach the switch on the dash and tubing that runs down the frame for coolant.
