Are they welded or bolted to the body? Either way or should not be an issue but I haven't pulled those panels yet.Rear interior panels. I'm looking for 1 -rear panel mounting bracket .
The Suburban interior panels are not like the K5 with stand off brackets.Rear interior panels. I'm looking for 1 -rear panel mounting bracket .
I have it all. The switch will be easy to access but I didn't pull the trim before filling it with scrap metal.Any chance you have this interior light switch for rear door or the chrome trim pieces for 3rd row seat mounting points. View attachment 411389
What's your price?I have it all. The switch will be easy to access but I didn't pull the trim before filling it with scrap metal
I have several sets of the linkage and at least one of the frame brackets. I also have several sets of the bushings as well. The only thing I may no have is the spring that goes between the bushing and shift linkage to push it away from the frame towards the transmission.. $40 plus shipping for a full set but I would need to check if it will all fit in a flat rate box or if I need to calculate based on zip code.do you have the automatic transmission shift linkage, from engine compartment side column to the transmission including the part that bolts to the frame?
I will have to look at what I saved in my wiring harness bin.Is the harness for the front lights and horns available. I need from bulkhead connector forward.
