So I have been chasing this issue for quite some time and I had thought I had it resolved. Well now I can replicate the issue and make it blow the fuse all the time. With the tilt all the way up I can turn the blinker on just fiine and with the blinkers on when I start to lower the tilt you can here the fuse pop. before I tear into this I figure I would post. So is it a turnsignal switch that I need or is there a wiring harness that goes throught there that needs to be replaced.
It would be a bonus if this resolve the cruse issue also. The cruse dose not work but it is all on the same lever.
thanks in advance
thanks in advance
