I decided to just cut out a section and reinforce it. This way it would be fresh and a lot stronger. I know you can't really tell but i marked out a rectangular section that was large enough to go around the nut and retainer cage but also observed the two body lines in the door frame marked by red. I was not sure if these lines where supposed to be there but appeared to be identical on both sides and so I elected to work around them as not to change the geometry of the door striker.
This guy uses a similar method as to the one i went through if anyone is looking for more detail.
lol
