I'm looking for some advice. I'm used to the K5 solid axle suspensions and the science of the pickup truck suspensions has me at a disadvantage.
The 1990 Silverado I purchased is probably in need of a mild lift. Probably less than 4" and hopefully between two and three inches. My issue is that it came with 285/ 55r20 Nitto's that were near the end of their life. Yesterday I went and got 275/ 65r20 Bridgestones. I thought I did the math right and I thought that the tires would fit fine but they do not. (1000% my fault - shoulda gone with 275 55/20's) The front tires definitely rub the lower edge of the front fenders and any compression will cause the tires to rub the front bumper. Without returning these tires, I'm assuming I need to lift the truck. I don't want to make it too crazy because I still want my wife to be able to get in and out of the vehicle. I also don't want to go crazy on the cost because I'm spending all my money on my Blazer build. That being said, I looked into some of the lift kits and specifically looked at Rough Country but decided against it since it has such horrible reviews. I am new to the concept of using a torsion bar to lift the truck but I understand the concept. I'm guessing I probably need a 2 OR 3 inch BODY lift but I'm also interested in some type of suspension lift. Any thoughts or ideas?
Can I simply get away with using the aftermarket torsion bar adjustment keys to get one or maybe 2 in of lift? I've seen several comments that say it is possible without lowering the differential. This also reportedly doesn't affect ride quality very much.
I am concerned about alignment and keeping it from losing alignment. The issue with positive camber is concerning. My thoughts on the back end would be to use an Add-a-Leaf instead of a block or maybe doing Add-a-leaf and using a 1 inch block if I need to lift it a little bit higher. Again, this will be simply driven on highways and dirt trails. No off-roading.
Any thoughts and recommendations are welcome. Also, I was planning on going with Bilstein shocks no matter what shocks may come with a kit.
