The suburban is acting up when it is cold, it takes a bit to get reverse to engage and 1st is a little better. Once I go down the road everything is fine and it shifts good, locks up when it is supposed to and no flaring. I pulled the pan and changed the filter and the pan was clean, no clutch material at all and the inside of the trans was clean. I'm hoping there is a simple fix for this.
