Parting Out 1991 Chevy K5 Blazer - Parting Out
Im interested in the gauge cluster, mainly the speedo. If it's the mechanical speedometer. I would take the whole cluster if it is.
pass lower mirror edge . chipped ? or just dirty ?
and I would want the specific black out door glass for mirrors if I do get .
Just went out and looked. There is chunk of plastic actually missing out of it right there.
What is the story on black out door glass? Is it like an anti glare finish?
going to pass on mirrors
and mirror mounts back so wing window opens . and section of glass is blacked out so you don't look at mirror guts when window is up . specific glass to 90-91 mirrors got this glass.
I would like the rear seat belt receivers that bolt to the body tub, dome light, and trim piece that the light mounts in (overhead, between both b pillars). PM price, thanks!
Honestly I just started looking. I hope not... I am doing a 4l80e swap and need VSS.
Found a SM465 out of a 90 K5 with all the necessary parts to swap trannies on this rig to manual. There have been no parts sold off of this to date. So, the budget built K5 idea is starting to blossom.
If $50 buys complete power mirror setup, I'd go for that. Would also go for passenger door glass.
My wants if it has
All factory plastic spark plug wire retainers
Map sensor & bracket
EGR Solenoid filter cap
all oil cooler line clamps, brackets & clips
oil cooler filter adapter bolts
power steering cooler under radiator support w/hoses & mounting hardware
My wants if it has
Just picked up the SM465. Going to put some 3/4 tons, small lift, and 37s on it.
If it has cruise, I could use the linkage that goes from the diaphragm on the firewall to the throttle body
Hows the motor for the tailgate window? I'll take it if it's doing OK.
Tailgate window motor on this rig seems to be stuck. I can disconnect the line and isolate the trouble more but I think there is probably a better option for you. I know I just bought two AC Delco door window motors for my Trazer off of Ebay for a pretty decent price. They had free shipping and are working great so far.
Ah, ok. If you do get around to it, please PM me and we can work from there. AFAIK, those tailgate motors aren't made anymore and we are stuck with whatever is left over.
