Parting Out 1991 Chevy K5 Blazer - Parting Out
Do you have the vents for the dash?
The climate control panel?
Does it have a stock steering arm?
Driver side seat belt? Does it work?
Driver's side pull strap?
The pull strap covers?
yes to all of the above.
How much for the electrical connector on the tailgate keyswitch. Funky round connector. Cant find a source for those.
I could use the rubber trim (ring) on the steering column (just before where it goes into the dash) and the lower plastic valance immediately blow that (held on with 4 screws) (could also use as many dash screws as you have!) , steering wheel (if still available), cup holder on centre box. If the light switch/dash light dimmer works I'd like that too. PM with a price and shipping to 22202. Thanks.
Seems like the rubber trim ring would be a PITA to get off but I'll check. Probably have the lower plastic valance. Steering wheels are easier to get off of ebay. Not splitting up the cup holder from the center box and not splitting up the light switch from the steering column. So, in summary, what's left is probably not worth shipping.
ok no problem. Thanks anyway :-)
