1991 k2500 build
priceygmc
fremont Michigan
priceygmc submitted a new Build:
1991 k2500 build
In 2009 i bought my first GM and shortly after it got a 6 inch procomp suspension lift fallowed with mickey thompson rims and pro comp xterrian 35 12.5 15 tires and last winter we repainted the hood front fenders and got a diff box that we painted to match the hood and fenders also last winter i built a 383 stroker i bought everything new from summit except the heads i had rebuilt by a local machine shop and got a big bore throtle body and put big block injectors in the pod which worked great until i purchased a set of dart pro 1 aluminum heads now its lean so now im converting it over to a Fast EZ EFI system i am currentally in the process of buying all the stuff i need to convert it i got the intake and the EFI system ordered.
Read more about this build here...
1991 gmc
Well I got my new edel Brock performer rpm air gap intake in and also have the fuel pump in for converting it over to fast EFI now I have to get a msd 6al programmable box and a fuel pressure reg. And I also got a Dana 44 high pinion from a 1976 f150 to do a solid axle swap with going to do triangulated 4 link coil over shocks and a psc full hydro steering kit
Well since Craig doesn't know how to post pics yet I guess I'll do it for him :haha::haha:
That is a pretty darn nice sticker on that truck i wonder where that might have came from?????????:laugh:
The press we built!!!!!
Nate Deuling and I built a H beam press and had to try it out on something!!
haha
You just never your mind about that press and go worry about how you put water in the beer pong cups.
It rips!!!
well i finally got the 383 running again with the new dart pro 1 aluminum heads and new MSD DIZZY with a MSD digital 6al programable box and a FAST fuel injection system thanks to Heath!! Im very impressed with the way it runs with the fast system i would recomend it again to others.
Intake
i also got a new edel brock performer rpm air gap seems to be a good flowing intake so far havent really had alot of time to test any of the changes out yet due to winter.
Nice and clean, man!
What trans are you running?
Hes running a 700r4 with transpak, transgo stage 3 reprogramming kit, corvette servo i beleive, and most every other goody they could cram in it.
Thing shifts AWESOME!!!!!!
