1991 Silverado 2500 pickup blend actuator
dmagas
Registered Member
Colorado
Anyone have an idea how to remove blend actuator. It is the last one on the right below glove box. I was able to get the bottom screw out but the top is near impossible don't know the trick. I have removed the glove box still no luck. I know I have the right actuator because the disconnected it and the little lumber jack in the console is quite now. When starting and turning off ignition tick tick tick tick for a good 30 seconds to a minute. I am told this is a common problem. Any help is appreciated.
