1991 v3500 - big dumb lifted forever truck
I have updated the parts list at the beginning if anyone uses it.
Also. These big rubber spacers on the engine mounts are pretty important. Keeps the fan from meeting the radiator.
ALSO!!! Finally able to legit have these gm diesel emblems and not be a poser!!
Brain scratcher on how to get the shifter to come through in a good spot. Made it fit with a stock shift lever too. This is the stuff people never finish. Cause it sucks!
Got a somewhat short list left but some of those are large and have sublists.
Girls- Can we buy new toys?
No, we have toys at home.
Now that I have put several thousand miles on it and I am very happy with the truck I figured I’d lend my details out. This is a culmination of learning from people much smarter than myself and I am infinitely grateful. Please ask your questions. I’d love to learn something new if you see something I could do to make this better.
Nitty gritty is it’s a 91 v3500 which was a tbi350 4l80 205 Dana 60 14 bolt with 4.10.
Now it’s a p pump 12 valve, g56, np205, Dana 70f/80 with 3.73 and 315s. Gets a consistent 17 and above mpg.
Pump has 4k springs, Mack rack plug, and afc live. Head has 60lb springs and arp studs.
Bottom end has 325k miles.
Haley speed 5x14 injectors, a phatshaft 62 12cm, steed speed manifold, and 18 degrees timing. Factory lift pump with 6.2L switchover valve and sending units.
Ron Bonney crossmember with energy suspension poly inserts to keep the motor from shifting forward. Second gen dodge oil pan.
Complete second gen dodge cooling stack fits exceptionally well in the stacked headlight core support. I am using two straight boost tubes instead of the bent dodge one. I also shortened them a little. Heater hoses are molded 90s into vintage air heater core.
Ac is a vintage air system with the f700 mid mount compressor.
Alternator is 240-4017 with rob Bonney upper bracket. Super convenient to use the dodge thermostat housing with the f700 brackets.
Gm power steering hoses into a gm ps reservoir on a 4bt power steering pump assembly.
Clutch is a Valair quiet dual disc and uses an obs ford master and dodge slave cylinder. I had valair make me this as a pre bled system. It is the Tennessee diesel kit with the firewall mount that is wedge shaped. 85-91 factory hydraulic pedals. You have to widen the bolt spacing from the original gm master cylinder bolt holes for the new master bolt spacing. Excellent driving clutch for a dual disc.
G56/np205 is an easy bolt up if using a dodge 205. I chose to use a clocking ring to bring it back flatter to gm clocking. Made fitting the exhaust a little easier. This combination is long enough to use a 5” diameter one piece slip yoke driveshaft. Worth it.
This is a third gen nv5600 isolator and 77-84 k30 trans crossmember.
Also here is a 1” body lift which really increases tool access to the trans and is nearly unnoticeable otherwise.
Using an hx40 down pipe for a w250 from diamond eye. Fits meh at best. I’m using the diamond eye first gen 4x4 kit until after the tcase. After that I switched to a 2wd kit which I like the routing and outlet location a little better. 4x4 outlet is angled instead of 90 behind the rear tire. This is not as bolt in as people make it sound. It’s a pain in the ass to make it look good.
Suspension is a pro comp 2.5 front spring which is 525 lb/in and nearly flat. 4 inch pro comp rear springs. Bilstien 5125s. Front axle is scooted forward 1” with push pull steering. It rides very not bad.
Axles are kingpin Dana 70 front, Detroit locker, and 35 spline spicer hubs.
2002 dodge disc Dana 80 with a trac lock. Parking brake cables fit together with no modification.
Gauges are a 4k tach fuel combo gauge from a medium duty square body with a board from Cajun tach shop to read the pickup system from isspro. R8912 with two extra magnets glued to the balancer. Reads just like a gas tach with a distributor. 4 pulses per revolution.
VSS speedometer is oem to the truck. Oil pressure and temp gauge came from medium duty as well. Classic instruments made me the boost and pyro how I requested them. It was a pain to fit them but I love em.
D354BFA9-DF0D-4987-87A6-6D431EF118E6.jpeg5A4BEA92-9971-4104-AA81-F81B3D8E7208.jpeg43F1D254-BF01-4E43-93AB-6DA0D7312660.jpeg509AC0E2-C24C-4975-B24D-77CD736D6FF8.jpeg72F00AF6-6A39-4DE9-B535-5457336A343E.jpegDA838A43-17B7-4C86-BC87-5D186862E748.jpegB46BEB9D-A894-40C7-820A-2F9582D4E8BE.jpeg5495F855-A3CA-492B-B6C9-2E679C6A3AAD.jpeg378A9D73-8978-48B1-BB87-CCF261D2E3B4.jpegE930380F-7D96-41BC-A1CC-426C05958E8F.jpeg106F8094-2DC7-4841-90A7-1E9DD7500EA7.jpeg306907A1-10B6-4386-A559-036690857AD2.jpeg4118F931-25C8-4B71-B47D-9603293E0665.jpeg44929E03-6D8A-449A-BB1D-BCC1A6C31D67.jpegC0F63ED2-328F-416F-8371-54D93EB37A4B.jpeg49BB7D94-77DA-4BDB-B4E1-E5D781F1AAC0.jpeg22B22182-9B71-45E1-964F-A8F83D10B8D3.jpeg9A684900-88C5-475A-B124-09AB8E4E2F69.jpeg
Great update and details! This has really turned out to be a super clean, the attention to detail shows. :lombardi:
Any future changes / updates planned?
It’s getting a ravelco theft prevention thing.
If I can, some ord spec springs. That would be cool.
That’s as perfect an engine combo if I’ve ever seen one. Truck is beautiful as is the build in general. Good job man.
Glad to see you kept it mostly stock . Any plans for paint, or leave exterior alone? Dont recall overall condition of the paint. Sweet truck, definitely would love to have something similar one day
Wow. Great update. The attention to detail shows. It has a whole "what if GM used a Cummins back in the day" kind of vibe to it. Keeping the OEM cluster had to be a chore but the results were totally worth it.
Awesome work for sure.
Ultimate square! :bow:
Three tits rated for sure!
Detail of this build is as nice as Larry’s builds. Beautiful work and usable.
Couldn’t help but notice the factory high idle… cool because I have one too!
What's your rpm at 65 mph with that setup?
This is 1750 at 65mph, kinda wish I went 4.10 which would be 1900 at 65. The amount of time it would be a tow truck is not worth the gear change now. I’m thinking of just getting some 285s for tow tires which would be about 1825 at 65.
Thanks guys. I don’t know if y’all remember but in 08 or so I bought my first 12 valve donor to swap into a k30. My dually at the time.
The 94 dodge was such a good truck I just drove the dodge instead.
This is how long it took me to actually make one happen. I have been thinking over this for a long time now and it is so worth it.
It’s sweet on a day like today. Mid 30s this morning.
Would you do it again? Honest question, just wondering if the juice was worth the squeeze.
100%
The paint is poor overall and if I do anything it would be preventative work on the roof. It’s nearly missing all its paint.
Paint is just something I can’t afford.
