1991 v3500 - big dumb lifted forever truck
obijuank5
1 ton status
Solutions
Central Texas
obijuank5 submitted a new Build:
1991 v3500 - forever truck
I still cant get over it.
I bought a 91 v3500.
Going to build this truck to be simple, reliable, and comfortable enough to take the family anywhere from the state parks to the county fair. And look ****ing badass while I do it.
Read more about this build here...
So this came off of a local training campus like a tech school. no idea what its duty was there but it has 80k miles and the maintenance intervals are written in paint pen on the fan shroud. Drove it home 30 minutes without a hitch. I will be the second titled owner.
Edit: August 2019. Cummins swap coming around nicely. this is just a bunch of record keeping, not really worth reading imo unless you're part numbering or something.
10 6.2 fender insulation
20 6.2 firewall insulation
50 hood insulation off ebay
400 flopro 847 does not work. Used it and diamond eye 220098 220097 22010 125005
220105 hx40 downpipe
400 tdc hydraulics kit - eventually had valair make hydraulics for the dual disc. Its a dodge slave but 97 f350 master. tdc bracket is very nice though, could just bend the pushrod instead.
1400 valair quiet dual disc
107 trans mount 52121774af didn't work. $70 Nv5600 52021470ad on 77-84 k30 crossmember
63 hydroboost hoses 36-349890 36-357640 36-368220
300 fuel tank kits gm1c sqst01 sp05m1h sp05n1h
52 selector valve FV5
60 filler hoses
20 diesel filler necks
150 nos fuel caps
650 manual tilt column
20 pedal assy
30 pedal rebuild pads and bushings
10 neutral switch ns120
30 driver side battery tray
160 starter 337-1099
200 block adapter
0 CAC tubes, boots, and clamps
100 VA condenser 037030-OVR
205 Radiator #2464 invoice 682 napa
239 Compressor #967236
233 alternator 240-4017N inv 2027312 ser# 345236
200 mopar shroud 94-02 dodge
60 mopar coolant recovery tank doesnt fit with the f700 accessories
6 dorman coolant recover cap POS
200 #8344 pyrometer
60 #8305 boost
80 Shifter knobs 52104174 55366060ab 52105001
20 temp sensor 213-1396 reads too low for oem 260 gauge. need 210 gauge and temp sender.
300 keating tappet cover - 120510-2V2
100 heater tubes usados. would buy stainless ones on ebay if I did it again.
175 pusher intake, slotted holes to move away from brake master.
52 turbo oil feed 3935821
50 oil feed fittings 4940183 x2
250 oil pan 3949338
25 oil drain ez104
50 belt k080694hd
105 tensioner 38517 inv 1950 napa
50 fan clutch 2798
0 fan hub and fan
0 balancer
280 oem motor mounts from dealer
350 power steering hub and hydroboost pump
8 filter 51607
20 filter 33402
70 fuel supply line 3936691
55 Fuel supply line 3918880
22 Fuel check valve 3924726
81 fuel line 3923171
58 p7100 oil feed line 3920736
8 banjo washers
400 adjustable timing gear
650 haley speed 5x.014 145* injectors
650 steed speed manifold
30 timing pin CON9498PTLP
350 afc live
10 p7100 rack cap
100 4k gov springs
50 adjustable overflow valve tork tek OFV020
80 throttle linkage ends
100 tach sender kit with two extra magnets for factory tach signal. ISSPRO R8906
1700 phatshaft 62 ps6270
385 bonney crossmember
450 arp head studs 247-4203
30 freeze plugs USE GREEN LOCTITE
200 cylinder head machine work w/ rocker pedestals
65 manifold studs
95 valve springs 60lb 1030060
260 mahle 95-3466
70 intake plenum cover
50 water pump cp6158
70 crank barring tool fpe-ccbt waste of money
70 water outlet straight 3943148
50 used f700 mid mount compressor brackets
65 alternator mount bonney
72 valve cover oil fill kit with timing cover plug
1x 3903463 Cover 1x 3903475 Rectangular Seal
270 oil cooler 3957544 DO NOT USE AFTERMARKET
75 dipstick assembly
800 1410 5" aluminum driveshaft.
np205:
106 bk205gdm4
130 jb shift rails and detents
200 vss conversion
30 coupler 29 spline. probably shouldnt have done this. time will tell.
110 front shaft 32 spline
25 skf sleeve 99187
Dana 80:
200 axle price
380 truetrac
250 yukon d80-373-4
275 g2 35-2080
50 perches
100 ubolts and plates
119 timken hub bearing and seals I wish I wrote these down. pain in the ass finding right parts.
112
50 natl 370150a hub seals inst June 25 2022
125 brake stuff sans rotors - cables pads shoes hoses
100 diff cover 2013834
oem 2002 dodge 2500 ext cab lb parking cables and adjuster #52008437AE dont remember what cables i used but they literally fell together. magic. short intermediate one didnt get used.
G56:
2800 trans price
100 pto covers
15 output seal
40 shift knob w/ cover
15 shifter top seal
you bet your orange loving ass.
well im putting that in. its a tbi 350 and a 4l80 now. barf. lol
So nice and clean! Going bigger or staying stock-ish or..?
Oh my...I do love me some square body crew cabs!! Going with an NV4500 to match your blazer? Mines an 89 (same grill), if I would have had the 4l80e, I would have left it and just focused on the motor, but mine obviously had the TH400 and I wanted overdrive, and the manual swap was real easy.
I'd say 8.1/NV4500 swap...but I'm kinda partial to that for some reason :pimp:
Awesome find!!!
I know I love my crew cab, but wish mine was just a little bit more square like yours.
Nice score for sure. Looks like it's in pretty good shape and looks to have one of those rare 4l80e/electric speedo np205 combos you only ever hear rumors about lol.
It is in fact one of the things that never seems to exist. This tbi 350 is nutless as hell and it needs 4.56s with these baby tires lol. It does chug along at 70 just fine though.
I ordered a bunch of crap for it this weekend and today. Notably the cheyenne pickup brand dash pad. Eager to see that piece. I will be ordering the usa1 front door panels to match the rears I picked up off 67-72 board.
Did some vent window latches. Made all the doors shut well. Fixed the tailgate lights and the dome light. This high tech truck has a buzzer when you leave the lights on!!!! Incredible. Going from and m1008 to this is like getting into a cadillac.
Am radio!! You gotta be kidding me! It works great.
I did find a wet passenger side floorboard. Doesn't smell like coolant alot but kinda does maybe a little. Either way it's saturated.
I did find a good spot of rust though. Not sure how to go about treatment.
Lastly the oil pressure gauge is wiggin out. Is that the one behind the distributor?
While I'm fixing the gauges I'm gonna try and install a tach. No clue how I'm going to do that.
Good luck with the tach install. The electric speedo clusters are pinned completely different from previous years plus there's a box shape place molded in to the cluster shell to accommodate the speedo circuit board.
I do have 91 FSM's if you want to use the wiring diagram book (or the other books).
