1997 K2500 Washer pump replacment? How do you get to it!?
73k5blazer
End the H1B Program!
The Rustbelt
Does anyone know the proper procedure to get the washer pump out?
I suspect you have to take the whole reservoir out. Does it come out from the bottom (remove inner fender well) or from the tpo(remove the battery,battery tray...some other cover or plate under the battery tray which I can't tell how it's fastened)
It looks very buried down there.
I confirmed power from the harness connector on the fender wall, but no pump...so I need to replace pump...damn that thing is buried!
if i recall you have to pull all out the way and possible the resivor. been a few years and few thousand cars/trucks/vans later. :doah:
It wasn't bad, just take it one step at a time...battery, battery tray, topshield (have NO idea what that's even nessesary..but whatever)...and then 2 bolts and the reservoir comes out, pump attached.
No sweat...20 minutes work! Well, one way...I still need to procure a new pump and put it in.
