Well I gotta ton of stuff done on the burb recently but.......left my camera at my parents the last weekend we were down
. Basically have everything bolted up. Had a new rear driveshaft made. 3 1/2"tube with 1410's at axle and 1350's at transfer case. got the front shaft bolted up 1310/1350 ujoint. Whole new driveshaft built with new ujoints and new 1350 slipyoke for tranny was only 300 bucks. both yokes in the axles are ubolt style
Need to get my new rear brakeline hooked up and fill/bleed brakes. Need to fill both front/rearend with fluid. Greased every zirt I could find haha. (gotta get two new ones for the bottoms of my knuckles cuz tehyre broken of)
Ran into some trouble with my X-over. I have a brand new bent draglink I can't use for the moment haha. I didnt know that if you have zerorates then the bent draglink and dropped pitman will cause the draglink to hit the leafpack without a spacer or thicker steering arm.Thing is I just bought the studs from skymfg for the arm i have
I just took my tierod off my 10bolt, chopped it down and had the cut-end tapped for 7/8-18 and have it on there as a straight draglink for now until i figure out what i wanna do. Also the 2wd steering box I mounted up had better lines/pump than mine was so i am using the whole thing, but one of the mounts for the pump needs to be modified cuz its a little off(different year or somethin probably) then fill steering fluid.
Then have to break out the cutting wheel and trim some sheetmetal. get some poser flex pics when I get it all done later this week(then I'll throw the shocks on haha)
This beast has taken a LOT of blood and sweat from me in the past few weeks and has been an AWESOME learning experience because I have never built or really done any serious work on anything like it before. This website has saved my ass a million times over in the past 6 months
Could've saved a few dollars here and there on this build but for a first real 4x4 rig, I think it's gonna be worth it to start with all the beefiest stuff that way I can spend more time learning the ropes of wheelin' than spending time in the driveway.
