PsRumors
If you have been following my burb build I have done a 2 1/2" ORD shackle flip. Before I torque the U-bolts figured I would get some opinions.
Plan has always been to get CV shafts from HAD once the trans is in and I can send measurements. Question is, would I be better off or just as good to shim the axle back down and run a regular shaft?
Wheelbase is not a problem. I am sure I still have plenty of length to run a standard shaft even with the additional length of the 4l80. I have not measured my angle yet but don't think it is bad.
Opinions, thoughts?
Opinions, thoughts?
