2.5" lift or 3.73 gears??
anatomiczero
Washington
2.5\" lift or 3.73 gears??
Right now it's at stock height with 32's and 3.08's I think. Should I get 3.73 gears, then lift and bigger tires. Or lift, 33's and gears? My acceleration isn't too bad right now with 32's, so 33's wouldn't be that much of a difference would they?
Re: 2.5\" lift or 3.73 gears??
I would be happier getting the gears first, lift second and tires 3rd... This would be the ideal order to avoid stressing out other parts (auto tranny, rubbing tires etc).
<font color="green"> Consider this one - getting new gears in your axle will run a minimum of about $1000 installed. Buying 3/4 ton running gear will cost about half that, and will already likely have 3.73s or 4.10s in them. Just throwing out a suggestion. /forums/images/graemlins/thumb.gif </font color>
yea..i think im going to have some 3/4 ton gear waiting when i put my lift in..would like to do it all at once..
Be a good idea. Wish I would have thought about this when I put the 6" lift in my Blazer.
the only reason i dread messing around with the suspension is cause every thing is rusted like a beotch!! lol..torch will be right at my side! /forums/images/graemlins/crazy.gif
Won't be that bad if you're putting on new springs. I'd go bigger the just a 2.5" lift. I went 6" lift and wish I'd gone higher.
ill probobly go 4..i would go higher but then i would need all new drive shafts and all kinds of stuff..who knows might need that even with the 4..ill probobly go for the 4" all spring rough country lift..if i cant afford it ill get the blocks then upgrade later on..its going to be a bisotch getting those springs out though..same with the shocks..u-bolts will have to be cut of..and i dont know how im going to get the spring bolts loose..ohh boy..
Rough country are just like thier name ROUGH. That's what I've been told. I have Superlift Softride springs and they are still a bit on the rough riding side.
well im sure any thing will be better than whats on there now...but no matter how good of springs you get i think all these older trucks will ride like a truck! lol..i just wanna drive mine!! /forums/images/graemlins/frown.gif
I hear ya /forums/images/graemlins/ears.gif You know you're in a truck in my K5.
man you should ride in my dads 79 3/4 ton if you want rough holy sh!t..of course his springs are totally shot and the shocks are cheap to so..lol man i want that truck bad..if i ever get it ..lift is the first thing thats going in it!
lol..well my dad has like ryder gas shocks or somthing when he put them on it didnt seem to make a bit of difference..
