2" lift on a first gen question
shady
1 ton status
iowa
If I do a 2" lift on a first 72 blazer will I still need lift shocks? the lift kit says its a 2" front /3" rear. I'm thinking if anything maybe just move the tabs on the axle up some. :dunno:
Moving the shock tabs is more work than just swapping shocks ... maybe cheaper, but a bunch of cutting and grinding and welding.
-- A
Kinda what I was thinkin:) I know thw shocks would be easier, but It may be hard to find the right size.
normal street ride I would say it would be fine, but if you plan on taking it off the road def not.
ORD sent me 2 Bilstein part# 33-185590 and 2 part# 33-185552 with my 2" first gen lift kit. They cost a little more, but I'm trying to eliminate as much of the 1st gen "buck" as I can.
Put the lift on but just leave the shocks hanging from the top mounts (not attached at the bottom). Take the truck and flex it out in a ditch or dirt berm. Then see if the shocks have enough up and down travel without bottoming out in either direction.
Ditch or berm? You can do it at home! :haha:
-- A
I was thinking of leaving the 3" body lift on it and not doing a suspension lift:dunno: . Its mainly a road vehicle with an occasional semi flat muddy road or ditch. It has 34x12.5's on it so I need something. I would run with no lift if it didnt require major cutting. I'm trying to keep it as stable as possible for my kid and I've been told in the past that body lifts are bad. This may not be true but I dont know.
