Gravel Maker
So, the first one is for a 14 Bolt C&C Axle, these have a much different offset but it is pretty easy to make and allows the use of the now standard 3/4 Ton Chevy front Calipers and Rotors......they are also 3/8" and bent and also only $50 a pair!
The second variation is for those of you using a standard SRW 14 Bolt axle and the pretty common C&C hub swap to gat a narrower width. Again, using the Chevy stuff and also only $50 a pair!
Thanks for all the input from CK5 guys as to what you want us to make! More in the days to come......
We have been making these for over 2 years for the C&C axle and have over 500 pair in use....
