How should this be setup in my truck?
I'm chasing down a driveshaft vibration and an wondering if the way my 2 piece shaft is phased could be contributing. I am going to be correcting for pinion a pinion angle too but just wonder what others know about the correct way to set up the phasing of this shaft.
The local shop that built my drivelines told me to run it with the first shaft slip yoke 90 degrees out of phase with the fixed yoke end.
I found some data in a Spicer install tech document that agrees with this. It says if the angle between the output yoke and shaft are within 1 degree of each other to set it up this way, 90 degrees out of phase.
Almost everything else I have found or others that I have talked to say to run it with the yokes on the shaft in line with one another.
I just setup the rear section like you would on a 1-piece shaft and left the intermediate section to fall where it ended up. I don't notice any vibrations but a 2-piece shaft with a CV is expensive.
