2 Piece Driveshaft Phasing
Cool article. My setup doesn't fit the examples though because I have a 2-piece with a CV joint. :doah: I just setup the rear section like you would on a 1-piece shaft and left the intermediate section to fall where it ended up. I don't notice any vibrations but a 2-piece shaft with a CV is expensive.
That's how I'd like to set mine up eventually too. Next time I have to build one, I'll copy cat your setup.
I think I'm really close to success here. I pulled my blocks and milled the 4 degree angle out of them so they are parallel top and bottom surfaces, This rolled the pinion down 4 degrees. I also built a couple of .250" zero rates to make up for the material I removed from the block and bolted them up to the spring pack. My driveline angles now match setup one from that article. T case and shaft one are directly in line, 3 degrees down. Shaft two is at 9 degrees down, so a 6 degree operating angle. Pinion yoke is at 2.5-3 degrees down, so an operating angle of 6-6.5 degrees.
Now I'm messing with the phase angle, when i put it back how my guy balanced it and told me to run it (90 degrees out of phase) it runs smoothest, SURPRISE. There is a band between about 2000-2500 rpm in 4th gear (SM465 1:1) where I still have a little vibration, but once you get past that it runs pretty smooth.
All the other orientations of the shaft phase I have tried are obviously out of balance, really noticeable vibes. I tried it with ujoints lined up in phase and at 180, also where it was balanced and 180 from there. I've had enough for the day so I'm calling it off for now.
My slip splines have just a little play in them, I wonder if that is maybe the source of the vibration I am still feeling? I may have the driveline rebalanced with the u-joints lined up in phase and see what happens?
I think it is close enough to run til I ditch the block and shackle flip the rear.
Yep, you have two possibilities here. The phase angle, and the balance weights.
A friend of mine builds driveshafts, and I have watched him balance them. He mounts it in the balancer. Hits a button, which locks the up and down motion of one end, then spins the shaft. The released end vibrates, and a strobe light shows the light spot. A readout tells how much weight is needed.
He has a big bucket of various scrap washers. He weighs different ones until he finds one the right weight. He tapes it on and tries again.
When its the right weight and in the right position, he spot welds it on and double checks the balance.
If its right, then he locks that end and respins it and balances the other end.
After that, he unlocks both ends and gives it one final spin.
So, in theory, each end is balanced. But you have to figure that even balanced this way, the weight on one end has to affect the balance of the whole shaft. And the shaft was balanced as one piece. So, when you turn the ends differently from the way they were balanced, it has to have some effect, just no idea how much.
The ideal situation would be to load up the shaft in a balance machine, check the balance and then change the phase and check again. But it would mean finding a driveshaft shop willing to do the experiment. Either for free or for a decent price.
Thanks for all the input guys, I learned a few things here.
