2 wheel peel / rebirth of a short bed c-10
Yeah, Colby pointed out the difference to me. I really prefer the '89-'91 style. I think the whit roof would look better down the back of the cab.
Martin
got a lot of smalls ready for paint work .
hinges / cups / link bars / latches / lots of bolts / and top sides of bed bolts also .
even got the brake assemble hanger unit blasted and painted black . unlike factory raw unit installed .
Very nice work on it.
This truck should look awesome when you get it done.:waytogo:
At least you remembered to paint the bolts that hold the tailgate arms on. I forgot to do that when I painted mine and I'm still driving around with primer gray bolt heads on a black truck. But my paint looks no where near as good as the job you're doing. :thumb:
I just cant figure out whats wrong with this thing . . . . .
darn body lines are off just a little bit . :dunno:
got good straight frame / new body bushings / NO body lift in it / test fitted before tear down for paint / don't see the problem do you ? :rolleyes:
on a good note . got the bolts and t-gate parts all painted today I posted pics of the other day I blasted .
I think you need to shim the cab supports up a tad. Probably something in the 18" range should get you close.
few pics of the bolts painted / t-gate hardware and bumpers on the box / and rubbers on the cab to seal the fender gap . no pic but got the wiper trans guts in place.
I cleaned up the seal on the cab and then painted them with SEM black dye. Made them look almost new.
if I cleaned them they would look like new . just little body shop dust .
the rubber tailgate bumpers I blasted in the cabinet with black beauty media at 6-8" away for less damage . those look like new now.
Brett, how ya going to keep those painted bolts from chipping when installing?
Something I haven't had success trying to do.
stuff still needs jambed out on doors and hinges yet so thay will get covered again . and what don't will get a bit of mixed paint on a brush and touched up .
well figured out the body line problem .
guess I just needed to install the parts on the frame of the truck to get it right :dunno::confused::doah::what:
stock 15x8 rallys . hen newer conversion lug nuts to run newer 88-up center caps . and 255/70/15 ( 29.1" tall ) bfg radial ta .
rims will be blasted and powder coated bright white.
going to leave off the chrome trim rings .
