yep semi floater rear. but pressed on the axle bearing and NO c-clip in the diff. this is over the reg semi floater rears that bearing is pressed in the axle housing and axle slides in and held with c-clips and if it breaks whole axle slides out of tube.
the ford 8" and 9" have the 3rd bearing support on the pinion like a 14 ff rear in our trucks. then the pinion unbolts and has a shim between the 3rd member to adjust pinion depth.
and also the carrier bearing preload and backlash adjustment is just like our 14ff rear with threaded collers.
the smaller bearing car rears had a reg semi float roller bearing on the axle. but the trucks got the big tappered roller bearing on them .
i went with it for 1 simple reason my current 10 bolt was shot bad breaks / ring & pinion toast and bearings junk . plus 2.73 gears in it.
ford 9" redo and cost was within budget and cost effective for mod's later down the road.
