Title says it all. I got the Astro as a cheap DD / work / gigging vehicle. I bought the only "work" Astro I could find in town.
Anyway, when in gear, sitting at a red light, it shakes. It's annoying enough that I usually take it out of gear while not moving. When I do, the oil pressure gauge needle jumps around violently, even though the van itself does not while in neutral.
Years ago, my Dad's Saab had a similar problem, and IIRC, it was a TPS.
Ideas? I need to go through it and do the usual tune-up process... plugs, wires, filters, thermostat, oil, etc...
Another thing I just thought I'd throw out there. It'll probably be fuel pump time soon. It whines pretty good. The thermostat needs replacement. It runs cold and the heater output sucks...
Thanks... ;-)
Thanks... ;-)
