2000 GMT400 CREW CAB SFA SWAP-The Warden: Fuel leak fixed and awaiting surgery…
The ultimate goal for this truck is tow duty/family camping trips/small offroad adventures.
No luck on a tall adapter @campfire.
Crossmember looks to be the same height as a 4x4 unit.
And it's still not leaking....
I don't see how that cross member can work with a transfer case. Unless I'm seeing it wrong. It looks like the cross-member comes up higher than the 6-bolt flange on the tranny case. And the BW flange will be slightly larger yet in diameter.
An optical Aeutian, perhaps?
Also, the adapter you have would put the cross member further forward vs. what you have now.
:popcorn:
If you go back to page 65, Luke put some pictures up of a 4x4 setup. It actually looks like it is fairly close. I need to get some side-by-side comparisons lined up.
Might have to drive the camper down to the shop and check Pop's fleet.
