Oh man that’s awesome!06 LLY
It’s usually around the passenger side battery.
Sound like I need to go take a peak.Yes, mine is ziptied to the batt cable...never got used in Texas.
Found it!It's probably bundled up and tied to a chunk of the harness under the air intake tube from the air filter box to the engine and just in front of the fuel filter assembly. Easiest access is to pull the intake tube out of the way. You should be able to see it and clip the zip tie they have it held in with.
Well I found it!!! So cool. Also found the window sticker from the dealer in the glove box. 1 owner trucks are fun.
Where do the block heaters come out from on these trucks? It has the K02 rpo code for the block heater.
I didn’t pull it out of the plastic yet.Under or behind the back seat?
The clips aren’t bent over if it hasn’t been used before... they are a bitch to bend over! And like Zoo said don’t try to put it on in the cold.
I use the mine in the winter. The heater works better with it.
Cool it was still with the truck!
Yeah instructions were in there. We’re pretty much done with winter, so I’ll check it out next fall.There should be tabs with snap buttons in the bag.
They go under the push pins for the plastic cover right above the grill under the hood. Instructions should be in the bag.
Having an issue where it says my right rear door is open when it’s not. I read that the latch is the sensor for the door switch, well that has been replaced and it’s still saying it’s open. Anyone ran into this issue? @max 02
Yep, the wire leading to the latch for the switch is probably broken. It's probably broken in the door jamb where the wires pass through. Could be broken inside the door, but the most common spot is the pass through.Having an issue where it says my right rear door is open when it’s not. I read that the latch is the sensor for the door switch, well that has been replaced and it’s still saying it’s open. Anyone ran into this issue? @max 02
The back foot on my mega cab had like 6 of the 8 wires broken. They give the door full 90 degree homes but only enough wires for 85 degrees lol damn dodges. Might check there first.Yep, the wire leading to the latch for the switch is probably broken. It's probably broken in the door jamb where the wires pass through. Could be broken inside the door, but the most common spot is the pass through.
His is a crew cab with forward hinges. But the same thing can happen. I will admit extended cab Colorado's were the worst culprit for that problem. Pretty easy to figure out on those though. The rear speakers are in those rear doors and usually, you'll lose the speaker on the same side the door ajar warning comes on.The back foot on my mega cab had like 6 of the 8 wires broken. They give the door full 90 degree homes but only enough wires for 85 degrees lol damn dodges. Might check there first.
So is mine. The hinges are on the b pillar.His is a crew cab with forward hinges. But the same thing can happen. I will admit extended cab Colorado's were the worst culprit for that problem. Pretty easy to figure out on those though. The rear speakers are in those rear doors and usually, you'll lose the speaker on the same side the door ajar warning comes on.
Im headed (against governors mandatory stay home orders) to Toledo to pick up a new project!
Give an update of your first experience w towing.
Good luck Greg.
And I should be rolling into Northern Kansas to pick up that 64C10, maybe we could meet up on my way back to MI.?
