2003 tahoe gauge cluster problem
k5blazin
Elizabethtown, PA
My mothers Tahoe cluster just went on the fritz. turn the key on and it does nothing.. no gauges, indicator lights, or back lights. checked the fuse and its ok... I took both battery cables off and touched them together to reset the system and it worked for a day or two now the problem came back.. any help??
There is a known issue with the stepper motors for the guages themselves.
2003 would be the prime time years for that issue. I don't know what to say about the whole cluster going down
Stepper motor fix is DIY easy.
This is a very common problem with these trucks. Im pretty sure you need to replace the whole gauge cluster itself. You can probably bet one from a salvage yard, but I would probably try an new aftermarket, or new OEM.
