I went with a regular 2005 GMC Yukon/Denali 4wd. I'm assuming it's the same whether it's an XL or 1500 or 2500.
Looks like a complicated one that definitely requires a scan tool according to AllData. There are 2 different procedures depending on if it has JL4 brakes or not. You have to do the scan tool bleeding procedures then you bleed the brakes like normal after that.
ABS Automated Bleed Procedure (w/o JL4)
Notice: When adding fluid to the brake master cylinder reservoir, use only Delco Supreme 11
(R), GM P/N 12377967 (Canadian P/N 992667), or equivalent DOT-3
brake fluid from a clean, sealed brake fluid container. The use of any type of fluid other than the recommended type of brake fluid, may cause contamination which could result in damage to the internal rubber seals and/or rubber linings of hydraulic brake system components.
Notice: Refer to Brake Fluid Effects on Paint and Electrical Components Notice in Service Precautions.
Important: This procedure may be performed on all vehicles EXCEPT those equipped with option code JL4, Vehicle Stability Enhancement System
(VSES).
Important: The base hydraulic brake system must be bled before performing this automated bleeding procedure. If you have not yet performed the base
hydraulic brake system bleeding procedure, refer to Hydraulic Brake System Bleeding (Manual) Hydraulic Brake System Bleeding (Pressure) in
Hydraulic Brakes before proceeding.
1. Install a scan tool to the vehicle.
2. Start the engine and allow the engine to idle.
3. Depress the
brake pedal firmly and maintain steady pressure on the pedal.
4. Using the scan tool, begin the automated bleed procedure.
5. Follow the instructions on the scan tool to complete the automated bleed procedure. Release the brake pedal between each test sequence.
6. Turn the ignition OFF.
7. Remove the scan tool from the vehicle.
8. Fill the
brake master cylinder reservoir to the maximum-fill level with Delco Supreme 11
(R), GM P/N 12377967 (Canadian P/N 992667), or equivalent DOT-3 brake fluid from a clean, sealed brake fluid container.
9. Bleed the hydraulic brake system.
10. With the ignition OFF, apply the brakes 3-5 times, or until the brake pedal becomes firm, in order to deplete the
brake booster power reserve.
11. Slowly depress and release the brake pedal. Observe the feel of the brake pedal.
12. If the brake pedal feels spongy, repeat the automated bleeding procedure. If the brake pedal still feels spongy after repeating the automated bleeding procedure inspect the brake system for external leaks. Refer to Brake System External Leak Inspection in Hydraulic Brakes.
13. Turn the ignition key ON, with the engine OFF; check to see if the
brake system warning lamp remains illuminated.
14. If the brake system warning lamp remains illuminated, DO NOT allow the vehicle to be driven until it is diagnosed and repaired.
15. Drive the vehicle to exceed
13 kph (8 mph) to allow ABS initialization to occur. Observe brake pedal feel.
16. If the brake pedal feels spongy, repeat the automated bleeding procedure until a firm brake pedal is obtained.
ABS Automated Bleed Procedure (W/JL4)
Important: The following procedures may be performed on vehicles equipped with option code JL4, Vehicle Stability Enhancement System
(VSES).
Pre-charge Bleed
The Pre-charge bleed procedure is to be performed when air may have been introduced into the precharge pump inlet hose, the precharge pump or the combination valve. Perform the procedure as follows.
Important: If the
brake system warning lamp is illuminated, DO NOT allow the vehicle to be driven until the concern is diagnosed and repaired.
1. Ensure that the
master cylinder reservoir is filled to at least the minimum-fill level with Delco Supreme 11, GM P/N 12377967 (Canadian P/N 992667), or equivalent DOT 3 brake fluid from a clean, sealed container.
2. Ensure the
master cylinder reservoir cap is ON securely.
3. Install a scan tool.
4. Turn ON the ignition.
5. Select the VSES Special Functions menu on the scan tool.
6. Select Pre-charge Bleed.
7. Press the On key. The precharge pump runs for approximately 3 seconds, circulating fluid from the master cylinder fluid reservoir, through the precharge pump and combination valve, then back to the master cylinder.
8. Evaluate the feel of the
brake pedal. If the pedal feels spongy, perform a base brake system bleed.
9. Ensure that the master cylinder reservoir is filled to at least the minimum-fill level with Delco Supreme 11, GM P/N 12377967 (Canadian P/N 992667), or equivalent DOT 3 brake fluid from a clean, sealed container.
Automated Bleed
The Automated Bleed procedure is to be performed when the
brake pressure modulator valve (BPMV) is replaced. Perform the procedure as follows.
Important: The base brake system must be bled before proceeding.
Important: If the brake system warning lamp is illuminated, DO NOT allow the vehicle to be driven until the concern is diagnosed and repaired.
1. Ensure that the master cylinder reservoir is filled to at least the minimum-fill level with Delco Supreme 11, GM P/N 12377967 (Canadian P/N 992667), or equivalent DOT 3 brake fluid from a clean, sealed container.
2. Ensure the master cylinder reservoir cap is ON securely.
8. Select Automated Bleed.
9. Press the On key. The precharge pump and
ABS pump run for approximately 6 seconds while air is purged from the BPMV.
10. Ensure that the master cylinder reservoir is filled to at least the minimum-fill level with Delco Supreme 11, GM P/N 12377967 (Canadian P/N 992667), or equivalent DOT 3 brake fluid from a clean, sealed container.
11. Perform a base brake system bleed.
12. Evaluate the feel of the brake pedal. If the pedal feels spongy, repeat steps 1-11. If the pedal feel is acceptable, proceed to the next step.
13. Ensure that the master cylinder reservoir is filled to at least the minimum-fill level with Delco Supreme 11, GM P/N 12377967 (Canadian P/N 992667), or equivalent DOT 3 brake fluid from a clean, sealed container.
Caution: Refer to
Brake Fluid Irritant in Service Precautions.
Notice: Refer to Brake Fluid Effects on Paint and Electrical Components in Service Precautions.
Notice: When adding fluid to the brake master cylinder reservoir, use only Delco Supreme 11, GM P/N 12377967 (Canadian P/N 992667), or equivalent DOT-3 brake fluid from a clean, sealed brake fluid container. The use of any type of fluid other than the recommended type of brake fluid, may cause contamination which could result in damage to the internal rubber seals and/or rubber linings of hydraulic brake system components.
1. Place a clean shop cloth beneath the
brake master cylinder to prevent brake fluid spills.
2. With the ignition OFF and the brakes cool, apply the brakes 3-5 times, or until the
brake pedal effort increases significantly, in order to deplete the
3. If you have performed a brake
master cylinder bench bleeding on this vehicle, or if you disconnected the
brake pipes from the master cylinder, you must perform the following steps:
3.1. Ensure that the brake
master cylinder reservoir is full to the maximum-fill level. If necessary add Delco Supreme 11, GM P/N 12377967 (Canadian P/N 992667), or equivalent DOT-3 brake fluid from a clean, sealed brake fluid container.
If removal of the reservoir cap and diaphragm is necessary. clean the outside of the reservoir on and around the cap prior to removal.
3.2. With the rear
brake pipe installed securely to the master cylinder, loosen and separate the front brake pipe from the front port of the brake master cylinder.
3.3. Allow a small amount of brake fluid to gravity bleed from the open port of the master cylinder.
3.4. Reconnect the brake pipe to the master cylinder port and tighten securely.
3.5. Have an assistant slowly depress the brake pedal fully and maintain steady pressure on the pedal.
3.6. Loosen the same brake pipe to purge air from the open port of the master cylinder.
3.7. Tighten the brake pipe, then have the assistant slowly release the brake pedal.
3.8. Wait 15 seconds, then repeat steps 3.3-3.7 until all air is purged from the same port of the master cylinder.
3.9. With the front brake pipe installed securely to the master cylinder - after all air has been purged from the front port of the master cylinder-loosen and separate the rear brake pipe from the master cylinder. then repeat steps 3.3-3.8.
3.10. After completing the final master cylinder port bleeding procedure, ensure that both of the brake pipe-to-master cylinder fittings are properly tightened.
4. Fill the brake master cylinder reservoir with Delco Supreme 11, GM P/N 12377967 (Canadian P/N 392667), or equivalent DOT 3 brake fluid from a clean. sealed brake fluid container. Ensure that the brake master cylinder reservoir remains at least half-full during this bleeding procedure. Add fluid as needed to maintain the proper level.
Clean the outside of the reservoir on and around the reservoir cap prior to removing the cap and diaphragm.
5. Install a proper box-end wrench onto the RIGHT REAR
wheel hydraulic circuit bleeder valve.
6. Install a transparent hose over the end of the bleeder valve.
7. Submerge the open end of the transparent hose into a transparent container partially filled with Delco Supreme 11, GM P/N 12377967 (Canadian P/N 992667), or equivalent DOT-3 brake fluid from a clean, sealed brake fluid container.
8. Have an assistant slowly depress the brake pedal fully and maintain steady pressure on the pedal.
9. Loosen the bleeder valve to purge air from the wheel hydraulic circuit.
10. Tighten the bleeder valve, then have the assistant slowly release the brake pedal.
11. Wait 15 seconds, then repeat steps 8-10 until all air is purged from the same wheel hydraulic circuit.
12. With the right rear wheel hydraulic circuit bleeder valve tightened securely - after all air has been purged from the right rear hydraulic circuit - install a proper box-end wrench onto the LEFT REAR wheel hydraulic circuit bleeder valve.
13. Install a transparent hose over the end of the bleeder valve, then repeat steps 7-11.
14. With the left rear wheel hydraulic circuit bleeder valve tightened securely - after ail air has been purged from the left rear hydraulic circuit - install a proper box-end wrench onto the RIGHT FRONT wheel hydraulic circuit bleeder valve.
15. Install a transparent hose over the end of the bleeder valve, then repeat steps 7 11.
16. With the right front wheel hydraulic circuit bleeder valve tightened securely - after all air has been purged from the right front hydraulic circuit - install a proper box-end wrench onto the LEFT FRONT wheel hydraulic circuit bleeder valve.
17. Install a transparent hose over the end of the bleeder valve, then repeat steps 7-11.
18. After completing the final wheel hydraulic circuit bleeding procedure, ensure that each of the 4 wheel hydraulic circuit bleeder valves are properly tightened.
19. Fill the brake master cylinder reservoir to the maximum-fill level with Delco Supreme 11, GM P/N 12377967 (Canadian P/N 992667), or equivalent DOT-3 brake fluid from a clean, sealed brake fluid container.
20. Slowly depress and release the brake pedal. Observe the feel of the brake pedal.
21. If the brake pedal feels spongy, repeat the bleeding procedure again. If the brake pedal still feels spongy after repeating the bleeding procedure, perform the following steps:
21.1. Inspect the brake system for external leaks. Refer to Brake System External Leak Inspection.
21.2. Pressure bleed the hydraulic brake system in order to purge any air that may still be trapped in the system.
22. Turn the ignition key ON, with the engine OFF. Check to see if the
Important: If the brake system warning lamp remains illuminated, DO NOT allow the vehicle to be driven until it is diagnosed and repaired.
23. If the brake system warning lamp remains illuminated, refer to Symptoms -
Hydraulic Brakes.
