cabledawg
Secret Squirrel
OK, back story is that the pump was leaking but not bad. I just kept on top of the coolant and maybe added a gallon every month or so. Fast forward to last night and I see a huge pool of antifreeze under the front and knew the pump finally gave out. Sure enough, got the old one out and I could see where it had been leaking from a casting joint under the thermostat.
Buy a new pump and thermostat, get it all installed and the engine now overheats, the heater doesnt work and it seems like the pump isnt even moving coolant. I changed out the thermostat for the old one thinking maybe the new one wasnt the right part and same thing. I've checked the coolant and its topped off, but when the engine is running hot,the hoses are all cold. So is it possible that the new pump is bad from the start? I'm pretty sure the belt got put on the right way, but even backwards, wouldnt the pump do something?
Frustrated as I now have three vehicles and all are out of commission.
Seems kinda messy (and it is) and impractical since the stock clamps would be near impossible to release without removing the fan shroud. I replaced mine with a traditional screw type clamp so its now easier to loosen/remove and all I have to do is take off the expansion tank.
