Ultimate cooling set up
Is the thermostat housing an accurate place to measure engine temp?
  • Yes
    Votes: 1 100.0%
  • No
    Votes: 0 0.0%
  • The head is a better location.
    Votes: 0 0.0%
  • Total voters
    1
Well, that sounds like good news. Just to be clear though I don’t have EFI. I’m carbureted. Regardless, I went ahead and ordered this very expensive gauge and a high flow Edelbrock thermostat to make sure I know what my temperature is at the intake. I’ll install it on the intake where my fan sensor is now and then I’ll move my fan sensor to the thermostat housing.
I’m still gonna get all my tune options checked out, there may be something there that’s also an issue. But at least I’ll have a mechanical, reliable temp.
Not intending to harp but I feel strongly that your extreme poor power problem ( and very possibly tied in with your temperature issues ) needs to be addressed FIRST !
Just don’t want ya’ to chase other issues down that have developed by something else - start with getting and verifying the motor status is good FIRST !
I’ve done the due diligence and just don’t want ya’ to overlook or dismiss what has already been mentioned - re read this post below by BLUE85; he’s pretty sharp and sees a potential problem in this area as well.
The all caps for the words “first” were meant to draw your attention and not to be a smartass.
There are a lot of very experienced and very sharp mechanically inclined folks , along with many old professional wrench turners , here and I believe that everyone of them would agree to GET THE MOTOR RIGHT BEFORE you continue chasing down this temp issue.
You’ve described extremely poor power performance to the point of having issues just pulling onto the freeway - timing issues need to be addressed.
There are more than too far advanced and pinging timing problems - you could be a tooth off and running very retarded which would cause the conditions you’ve described.
Hope this helps - I won’t bring it up again and continue to harp on it… Tom
Thanks Tom, the way I phrased that may have been a little misleading. I’m getting a temperature gauge, just so I have an accurate reading of what the temperature is. I’m not expecting it to fix any problems even if the temperature is lower than the dash, which it probably will be. And the thermostat, just because I’ll have the housing off already to put my dual port housing back on instead of the no port one I have on there now.
I have a list of issues written down to bring to my mechanic. In fact, I’m gonna go to a different mechanic to get a fresh set of eyes.
It’s hard to know when I’m the only one driving it and you know, you get what you get sometimes. It’s slow seems to underperform, doesn’t act like any V8 I’ve ever owned but, I’ve never owned a four-wheel-drive with low gears, lifted with bigger tires so...
I really am a 2 WD guy stuck in a four-wheel-drive body. At least that’s what I tell my wife.
But I can see from the post that it’s likely there’s some kind of performance issue that needs to be addressed, in the form of the many things that were brought up.
So please don’t feel like you’re harping, I don’t take it like that at all. I super respect your guys’s opinions and feedback and it’s what I love about this site. I’m an OK parts replacer but I’m no mechanic.
And 60% of the time, I follow advice every time.
